Specified iteration completed but not converge |
December 15, 2015, 17:34 |
Onur
Rep Power: 11 |
Iterations I have specified have been still continued( totally 500) but is still converged in 3d flow All equations are like linear. Is it absolutely necessary to see converged? or is it enough as all equations are linear? https://imageshack.com/i/pbeqGtmtp Can anyone help me out with this information ? |
December 16, 2015, 09:12 |
#2 | |
Well on the other hand, one can say that the solution is converged even if the residuals are high if you are observing a paraemeter such as CL, CD, or pressure at a point and it's not changing with flow time or iterations or changing with a periodic pattern. So perhaps you should observe a quantity of interest at a surface, line or a point you are interested in and see if that quantity of interest. |
December 16, 2015, 13:47 |
#3 | |
Onur
Rep Power: 11 |
Thanks for replying. What does CL and CD stand for? After I wrote down this post yesterday, analysis have been converged in 357 iteration. But some results are unrealistic like total heat transfer rate, ( shown as 270w but I have calculated 770kw by hand.) mass flow rate etc. Results>Reports>Fluxes>Total heat transfer rate as a post processing,CFD-Post is better than field ''results'' of Fluent.? |
December 16, 2015, 14:14 |
Regarding your last question; CFD post is the official post processor for ANSYS so it should be much better. I don't find fluent bad as well.
and It is common to diverge away from thoery. There are so many things you need to keep track of and be cautious to come closer to experimental/hand calculated data. I am not an expert in thermodynamics or anything that involves heat transfer. I hope some one else pops in to clarify your issure |
December 16, 2015, 15:34 |
#6 | |
Onur
Rep Power: 11 |
Thanks in advance for valuable informations. |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
Hardware-Configuration for Fluent HPC-Pack (8x) | JohHaas | Hardware | 9 | March 3, 2015 14:25 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Parallel runs slower with MTU=9000 than MTU=1500 | Javier Larrondo | FLUENT | 0 | October 28, 2007 23:30 |
