December 2, 2015, 20:48 |
Compressible flow in vacuum condition
Hamid
So I am trying to simulate a train in a tunnel in a vacuum condition. First Question, Do I need to always consider compressible flow? or is compressible flow only for velocities of greater than mach 0.3 ? Second Question, if I want to model it as compressible flow, for the boundary condition if I use pressure-inlet then how do I make my train move in the flow? because by using velocity-inlet which I suppose is for incompressible flow you can give magnitude and direction and keep the train stationary. Thank you for your time. |
How to set the velocity inlet boundary condition in the compressible flow? | lienien | FLUENT | 2 | March 11, 2013 09:25 |
Compressible Flow problem | verma_rahul | Main CFD Forum | 0 | June 2, 2012 19:36 |
About compressible flow at low mach | hit | Main CFD Forum | 2 | October 26, 2009 22:21 |
periodic condition for compressible flow | ricklee | Main CFD Forum | 1 | November 15, 2006 01:23 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 14:19 |
