How does ANSYS Fluent calculate its enthalpy? |
November 28, 2015, 06:46 |
Rep Power: 11 |
Hey guys!
I am working with ANSYS Fluent at the moment and now there appeared a question. I wrote the User-Defined Funtions, one for the density and one for the viscosity - both dependent on the enthalpy. While running the calculation with one of these UDFs I set the other parameter (density or viscosity) constant. All other settings stayed the same in those two calculations. Now ANSYS Fluent gave me different enthalpy-values in both calculations. Now I am a bit confused because the density and the viscosity respectively should be calculated based on the enthalpy-values and not the other way around. So can anyone help me and explain to me why I have different enthalpy-values when I just changed the terms for density and viscosity? Thanks up front! Last edited by RebeccaKn92; November 28, 2015 at 08:45. |
June 4, 2018, 06:20 |
#2 | |
DU Shen
Rep Power: 10 |
hi, did you figure out the enthalpy calculation in FLUENT?
density, enthalpy, udf, viscosity |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
UDF Defining in ANSYS FLUENT 16.2 in Win 10 | Sadegh.A | Fluent UDF and Scheme Programming | 11 | February 15, 2017 15:45 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 06:31 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 04:17 |
