Rep Power: 0 ![]() |
Hi all,
I am running 2D simulations for a vertical axis wind turbine in Ansys Fluent. The wind speed is fixed at 10m/s, and I am gradually increasing the rotational speed of the turbine in a series of simulations. I am taking the moment coefficient (Cm) of the wind acting on the turbine blades, then multiplying by tip-speed ratio (TSR) to find the performance coefficient (Cp) of the turbine. Cm & Cp should increase as TSR increases, then begin to decrease as I pass the turbine's optimal TSR. The problem is that Cm & Cp are not decreasing; they are continuing to increase, even at speeds far above the typical optimal TSR. Does anyone have any idea what I might be doing wrong? Thank you in advance. |
Have a nice time!
Rep Power: 11 ![]() |
Have you solved the problem?
fluent, moment coefficient, performance coefficient, tip speed ratio, vawt |
VAWT simulation rotation domain | steve20024 | Main CFD Forum | 0 | March 2, 2015 03:37 |
Modelling a non-straight bladed VAWT in OpenFOAM | akku | OpenFOAM Running, Solving & CFD | 1 | June 20, 2013 05:23 |
fluent VAWT simulation | ahmed_yousry | Main CFD Forum | 0 | January 26, 2013 06:25 |
cm-history power coefficient in VAWT | yochule | FLUENT | 0 | February 14, 2012 17:43 |
NACA0012 Data as a function of Re for a VAWT model | psd | Main CFD Forum | 1 | July 31, 2009 22:04 |
