Setting surfaces for area weighted averaging in Fluent
Old   November 27, 2015, 04:53
Default Setting surfaces for area weighted averaging in Fluent
Tim
Tim123 is on a distinguished road
Hi there,
I was wondering if anyone could help me with the following question.
I'm modelling the flow in an enclosed channel, and I'm trying to get an area weighted average of the flow velocity in an area downstream of an obstruction. The channel is aligned along the z-axis, and ideally, I'd like to get the area weighted average of a portion of a channel section, not across the entire channel. Ideally, I'd like to get the area weighted average across a circle parallel to the XY plane, with radius and Z-offset from the origin that I can define.
I'm sure it must be possible to do this in Fluent, but I can't find out how. Unfortunately, I haven't included these surfaces as named selections in my setup, I hope this won't be a problem, as the run has just finished after 4 weeks!
Many thanks in advance!
Tim123 is offline   Reply With Quote
[ANSYS Meshing] Help Generating Multiple Surfaces as a Multibody in Ansys Fluent twolf59 ANSYS Meshing & Geometry 2 September 22, 2014 15:21
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
setting fluent to get pressure velue record ashar FLUENT 2 October 13, 2012 00:19
Setting up a 3DDP Fluent Model Jaeson FLUENT 3 October 4, 2012 09:46
problem in setting environment in fluent 13.0 ravindra FLUENT 2 July 27, 2012 09:38
