Water-Salt Solution - FLUENT
Old   November 25, 2015, 11:45
Angry Water-Salt Solution - FLUENT
SAM
CSolarFD is on a distinguished road
Hi everybody
- Does anybody know how to define a water-salt solution in fluent?
- How to construct a three different layers for this water salt solution ( different salt concentratoins) ?
Thanks
CSolarFD is offline   Reply With Quote
Old   November 26, 2015, 09:34
Question
SAM
No answer !
Old   December 1, 2015, 09:00
Question
SAM
Any suggestions ..
Salt dissolved in the water .. How to define that in fluent please?
Last edited by wyldckat; December 1, 2015 at 16:20. Reason: merged two posts posted on the same day
Old   July 28, 2017, 08:35
zobekenobe
zobekenobe is on a distinguished road
Use the species transport model without reactions. this will allow you to create a mixture template in which you could define the pseudo material (salt water solution) by defining the properties straight away.
zobekenobe is offline   Reply With Quote
Old   July 31, 2017, 05:17
MayTheFlowBeWithYou's Avatar
I have to remain anonymous, I'm sorry.
Location: The Netherlands, Delft University of Technology
MayTheFlowBeWithYou is on a distinguished road
I have been doing this by using a user-defined scalar, which represents the mass fraction of salt.
MayTheFlowBeWithYou is offline   Reply With Quote
Old   July 31, 2017, 06:07
zobekenobe
Can you share some details or the strategy employed? Would be of great help
Old   July 31, 2017, 09:58
Well, a lot of it would depend on what you exactly plan to do with the saline solution. But in the most simple case you could just activate one Use-Defined Scalar (UDS).
If you look in the manual (1.3.1. Single Phase Flow), you'll find the transport equations Fluent will use to handle this UDS.
As you can see from the equations it tried to make the scalar itself dimensionless. This means that the diffusion coefficient used is multiplied by the density (so if you specify the diffusion coefficient of salt in fluent you will have to multiply by the density, otherwise you'll be 1000x too low).
This also implies that, for concentrations, the scalar effectively represents a mass fraction. Thus if you just specify the mass fractions at the inlet(s) and outlet(s), you'll have a simple system that can have a concentration of salt moving through it.
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Initial solution fluent fevi84 Fluent UDF and Scheme Programming 1 June 23, 2012 13:10
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
