Unassigned interface zone problem in Fluent 6.3
Old   November 24, 2015, 01:44
Default Unassigned interface zone problem in Fluent 6.3
Piyush
piyushchauhan94 is on a distinguished road
I'm working on simulation of multiphase bubble flow inside a column partially filled with water with air being bubbled through it as shown in the figure.
After creating the geometry in Gambit 2.4, I assign the Air-water interface as 'Interface' boundary condition. On exporting it to mesh, it shows no error.
But when I run the mesh in Fluent 6.3, during Grid Check, it displays WARNING : UNASSIGNED INTERFACE ZONE DETECTED FOR INTERFACE 6. .........WARNING : GRID CHECK FAILED.
Later while assigning BCs by Define > Boundary Conditions, I find there are no options available for interface at all.
And when I try to initialize, I get - ERROR: INIT_FLOW : UNASSIGNED INTERFACE_ZONES.......ERROR: OBJECT: ().
Please please please help me out as of what I'm doing wrong. Is there any other way by which I can demarcate the top air part from the bottom liquid part ?
Thanks in advance
piyushchauhan94 is offline   Reply With Quote
Old   November 24, 2015, 04:48
ghost82's Avatar
Rick
ghost82 will become famous soon enough
this is a VOF simulation; you don't need to define a boundary condition "interface" for the water air interface.
You can define 2 fluid regions, named water and air for example, or you can define one fluid region and patch the secondary phase region in fluent.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
fluent shows that the the interface zone overlap Aysiyi FLUENT 14 November 21, 2020 12:02
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Unassigned interface zone detected ??? pah FLUENT 0 June 20, 2005 11:40
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 06:56
