Bubbles Phenomena on Pool Boiling Using PCB as a heater
Old   November 23, 2015, 02:07
Default Bubbles Phenomena on Pool Boiling Using PCB as a heater
Elvira Fidelia Tanjung
mtfl is on a distinguished road
Hello everyone,
I'm newbie in ANSYS Fluent (CFD simulation).
I want to make a simulation of Pool Boiling using PCB as a heater.
Here is my geometry. I set up the heater's material as copper and the rest as aluminium.
I ran the simulation with the Heater Temperature 403K, while the backflow total temperature is Saturation Temperature (373K). I applied the UDF from the ANSYS tutorial (horizontal film boiling) and changed the latent heat as Water Latent heat.
And also I set the Custom Field Functions :
403 - (y-0.05) * 30/0.25
Where Y = 0.05 m, the temperature 403K
Y = 0.25 m, the temperature is 373 (403-373=30K)
I think I need to set another Custom Field Function for the X coordinate, while the heater started at (x,y)= (0.07, 0.05) to (0.23, 0.05), but I have no idea how to set this one.
The result that I have is, there are bubbles but not even one from the heater, where I think should be from the heater.
If you don't mind, please share your experiences and knowledge about this problem. Thank you very much, May GOD reward you more.
mtfl is offline   Reply With Quote
bubble rising, fluent, pcb heater, pool boiling
simulating POOL BOILING......... Deepak Govindan Phoenics 2 November 18, 2008 14:38
guide me to solve boiling water using heater rizal CFX 5 January 17, 2008 13:32
HELP!: swimming pool flow problem Tee FLUENT 1 September 8, 2005 09:29
HELP!:CFD modelling using FLUENT in swimming pool Tee Main CFD Forum 0 September 7, 2005 21:48
pool boiling curve David Gibson Main CFD Forum 0 November 11, 1998 00:06
