Flow rate at outlet
Old   November 22, 2015, 16:03
Default Flow rate at outlet
Martin Nolan
mnolan93 is on a distinguished road
Hi all,
I need to calculate the flow rate at the outlet of my problem. However I'm not sure how to do this (pressure inlet, and pressure outlet bcs are used).
Any advice?
Thanks!
mnolan93 is offline   Reply With Quote
Old   November 22, 2015, 17:03
Kirill Sitdikov
ksitdikov is on a distinguished road
I don't understand your question, but I think you should to use a Report->Fluxes
ksitdikov is offline   Reply With Quote
Old   November 22, 2015, 17:06
Martin Nolan
I have a 2d pipe and I define the gauge pressure at the inlet and 0 gauge pressure at outlet. I need to find the flow rate at outlet.
Thanks for your advice!
Old   November 22, 2015, 17:13
Kirill Sitdikov
Are you a student?
See this on page 139.
Old   November 23, 2015, 16:57
Bhargav Bharathan
bhargavbharathan is on a distinguished road
Set your BCs and run the simulation. Then click Reports > Fluxes > Select mass flow rate and the boundaries > compute.
-BB
bhargavbharathan is offline   Reply With Quote
Old   November 24, 2015, 03:37
ghost82's Avatar
Rick
ghost82 will become famous soon enough
As alreaready reported check report-->fluxes, select outlet and read your flow rate.
Important: that value is calculated taking into account the value of "Depth" in the reference value panel, for the 3rd dimension.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Plotting mass flow rate at outlet for transient simulation Rakib Fluent Multiphase 4 September 6, 2015 00:46
DPM total mass flow rate yow FLUENT 0 July 17, 2015 13:01
Problems in pressure when using mass flow rate outlet rafiktharwat CFX 11 January 2, 2014 18:21
Fixed Flow rate and outlet Continuity Problem mrshb4 OpenFOAM 1 March 10, 2012 15:32
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 11:44
