Reverse Flow In NanoFluid Based Double Pipe Counter Flow Heat Exchanger
Old   November 15, 2015, 10:33
Default Reverse Flow In NanoFluid Based Double Pipe Counter Flow Heat Exchanger
Nabid Aunjum Hossain
nabidinhomessi is on a distinguished road
I want to simulate nanofluid flow in a double pipe counter flow heat exchanger with hot water as outer fluid.The main objective is to observe the pressure drop and Nusselt number with Reynolds Number(Turbulent Flow).It converged for laminar flow but showing reverse flow problem for Turbulent.
Mesh Used:Fine,Default Mapped Face Meshing
BC:Hot Inlet-Velocity Inlet
Cold Inlet-Velocity Inlet
Hot and cold outlet are both outflow
nabidinhomessi is offline   Reply With Quote
Pipe flow heat transfer feedq FLUENT 10 November 26, 2014 09:23
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[ANSYS Meshing] double pipe heat exchanger meshing in ICEM CFD chitra ANSYS Meshing & Geometry 0 April 13, 2013 09:36
[GAMBIT] double pipe heat exchanger with helical fin around inner tube mozafarie ANSYS Meshing & Geometry 5 November 7, 2012 06:02
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
