Reza Rohani
Rep Power: 11 ![]() |
I'm new to fluent. I want to simulate a rectangular nozzle in 2D. Wondering when I use mesh NO.1 it converges properly after 17500 iterations, but in mesh NO.2 when I refine it near throats and cavities even without add boundary layer, residuals oscillate and it doesn't converge after 270k iterations.
I really appreciate it if anyone could help, Thanks in advance.
Knowledge is power and it can command obedience. Remember that knowledge is a ruler and wealth is its subject. The Peak of Eloquence, Saying 146 |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
What do your mesh metrics say?
It looks like there's too rapid area/volume change in the regions where you refined the grid, especially at the outlet. Keep your volume change <33% or so between adjacent cells. But also check your skewness. It's hard to tell if the skewness was worse the refined grid in the picture. |
#3 | |
Reza Rohani
convergence, fluent, nozzle, nozzle simulation, oscillating residuals |
Convergence problem in Fluent for quenching process | kaeran | FLUENT | 4 | December 1, 2014 02:14 |
Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 06:03 |
Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 09:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
