Hot pockets appeared at the solid(Al)/PCM interface?
Old   November 10, 2015, 04:47
Default Hot pockets appeared at the solid(Al)/PCM interface?
Mohamed
B.Hamada is on a distinguished road
Hello.
During the melting of the phase change material in an Aluminium*rectangular enclosure , simulated by Fluent, I met a thermal problem in the wall that separates aluminum and PCM.
As shown in the attached figure, hot pockets appeared at the solid(Al)/PCM interface,*So how can I solve this problem?*
B.Hamada is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
