Setting Surface Tension in TUI
Old   November 7, 2015, 13:49
Smile Setting Surface Tension in TUI
CWL
cwl6750084 is on a distinguished road
Does anyone know how can I set the surface tension in the journal file for VOF calculation in FLUENT? I tried searching on the internet (for hours) and found this: solve/set/surface-tension, but it seems that it is setting the numerical solver and not the value of surface tension. Any ideas? Thx.
cwl6750084 is offline   Reply With Quote
Old   November 9, 2015, 01:14
Lucky
It's best to learn for yourself how the TUI works.
Check the Fluent manual for a list of all TUI commands. Or press enter into the TUI and you'll get a list of currently available commands. The TUI commands are very similar to the steps you go through in the GUI.
Old   November 10, 2015, 08:05
CWL
Thank you for the advice. I usually only use TUI to change one or two parameters, such that I do not have to use the GUI to create a new case file everytime. However, I could not find a command for surface tension. When I searched the manual in my office, the only one that came up was solve/set/surface-tension. This one does not do what I needed. I was wondering if there is a TUI command to modify the value of surface tension.
multiphase, surface tension, vof
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
surface tension gradient using UDF; surface tension gradient as function of temperatu marimuthusundar Fluent UDF and Scheme Programming 0 June 21, 2012 05:48
Surface tension problem. Kes FLUENT 0 May 19, 2008 23:49
Surface Tension Force Model Miguel CFX 7 October 2, 2006 06:30
surface tension model in EX26 Junhua Wu FLUENT 0 June 7, 2000 11:49
