Jordi Pina
Rep Power: 11 ![]() |
Hello!
I am exporting the velocity in the inlet and surprisingly, when I select Location: Node here: ![]() I obtain: nodenumber x-coordinate y-coordinate velocity-magnitude 1.000000E+00 -1.000000E-06 2.999711E-03 1.394836E-05 2.000000E+00 -1.000000E-06 2.999839E-03 7.749091E-06 3.000000E+00 -1.000000E-06 2.999968E-03 1.549818E-06 When I select Location: Cell Center, I get the following values: cellnumber x-coordinate y-coordinate velocity-magnitude x-velocity 1 -1.000000E-06 2.999705E-03 1.408548E-05 2 -1.000000E-06 2.999716E-03 1.364665E-05 3 -1.000000E-06 2.999727E-03 1.314436E-05 4 -1.000000E-06 2.999737E-03 1.263530E-05 5 -1.000000E-06 2.999748E-03 1.211906E-05 6 -1.000000E-06 2.999759E-03 1.160301E-05 7 -1.000000E-06 2.999770E-03 1.108668E-05 8 -1.000000E-06 2.999780E-03 1.057400E-05 9 -1.000000E-06 2.999791E-03 1.003785E-05 10 -1.000000E-06 2.999802E-03 9.534894E-06 11 -1.000000E-06 2.999813E-03 9.015264E-06 12 -1.000000E-06 2.999823E-03 8.497882E-06 13 -1.000000E-06 2.999834E-03 7.980660E-06 14 -1.000000E-06 2.999845E-03 7.464186E-06 15 -1.000000E-06 2.999855E-03 6.947777E-06 16 -1.000000E-06 2.999866E-03 6.431521E-06 17 -1.000000E-06 2.999877E-03 5.915332E-06 18 -1.000000E-06 2.999888E-03 5.399133E-06 19 -1.000000E-06 2.999898E-03 4.882863E-06 20 -1.000000E-06 2.999909E-03 4.366684E-06 21 -1.000000E-06 2.999920E-03 3.850696E-06 22 -1.000000E-06 2.999930E-03 3.335010E-06 23 -1.000000E-06 2.999941E-03 2.819924E-06 24 -1.000000E-06 2.999952E-03 2.305564E-06 25 -1.000000E-06 2.999963E-03 1.795914E-06 26 -1.000000E-06 2.999973E-03 1.294742E-06 27 -1.000000E-06 2.999984E-03 8.022501E-07 28 -1.000000E-06 2.999995E-03 3.713278E-07 Why do I get only three values when selecting Node? If I display the nodes I have 28 in the inlet, what matches with the cell center exportation result. ![]() I will appreciate your help! |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Make sure you have correctly selected the same settings. You actually didn't output any velocities for the node output so maybe you made a mistake and chose the wrong surface.
If you want all the face values you should select "cell center" and select the inlet. If there are 28 faces, then there should be 30 nodes when you write the export. |
Jordi Pina
Dear LuckyTran,
I want the velocity values of the inlet boundary condition nodes. Why if I select "nodes" I get only three results? Thanks! |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
'cell relative: velocity magnitude' vs 'velocity magnitude' | alpharays | Main CFD Forum | 2 | June 18, 2015 07:24 |
Obtaining angular velocity given linear velocity and center of rotation 3D | quarkz | Main CFD Forum | 6 | April 7, 2014 05:50 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
