NOx Simulation
Old   November 6, 2015, 08:47
Default NOx Simulation
Linwei
Yezi is on a distinguished road
I want to add NOx model based on a transient single coal particle combustion model, but I am a bit confused about the steps introduced by the User's Guide.
Step 1: Calculate your combustion problem using Fluent as usual;
Step 2: Enable NOx models.
Step 5: Run calculation
Does it mean that enable and run NOx model after finishing running usual combustion problem or run the two model together by setting them together through step 1 and 2?
I will be greatly appreciated if anyone can help. Thanks a lot.
Yezi is offline   Reply With Quote
Old   November 6, 2015, 13:44
Lucky
The NOx model in Fluent is a post-processor. You run the NOx model after you have solved the reacting flow-field. Run them separately.
Old   November 9, 2015, 08:21
Linwei
Thanks a lot.
But the problem is that, as my model is about burning a single coal particle under transient, if I ran NOx model after the particle had burned out, there was no NO ppm reported; if I ran NOx model together with combustion model, there was NO ppm reported...So, I am quite confused...
PS: I set the NOx model followed the steps in tutorial.
Old   November 10, 2015, 14:12
antonio
safdar is on a distinguished road
hi dear friend
i have a problem like u.
if you can solve your problem please help me
thanks
safdar is offline   Reply With Quote
nox
Waterbell Simulation o.b.m Fluent Multiphase 1 November 5, 2015 06:55
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 17:06
Axial fan simulation in UG/NX 7.5 fan123 Main CFD Forum 2 April 23, 2011 09:22
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
Simulation nox cui FLUENT 0 May 9, 2006 05:41
