How to set parameters for Steam Flow through valve? |
November 5, 2015, 17:34 |
adas
I am doing analysis of steam flow through main stop valve but fluent shows only water vapors and i am confused where to set temperature and pressure parameters.
Parameters are as following Temperature 478.6 F Pressure 559 psia Moisture 0.26% Any suggestions will be appreciated. |
fluent, parameters, steam, steam flow, valve |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
set BC mass-flow-inlet via UDF and via GUI perform different result | sawa25 | FLUENT | 1 | February 25, 2015 00:51 |
How to show the transient case? | H.P.LIU | Phoenics | 7 | July 13, 2010 04:31 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
How to set turbulence parameters at periodic BC? | Ray | FLUENT | 2 | July 28, 2000 04:15 |
