2D, VOF, AIR and WATER flow, around circle, what's wrong ?
Old   November 5, 2015, 17:43
Default 2D, VOF, AIR and WATER flow, around circle, what's wrong ?
Jakub
undziabundzia is on a distinguished road
Hey, I am doing tests, before finally, I will do 3d around ship 2 phase flow.
I have problem, at the end od farfield, just next to water pressure-outlet. There is weird high pressure area, how to reapair that ?
VOF, k-omega, 2 phases flow air, water, water-air surface tension 0.073, 2 velocity inlets air+BC, 2 pressure outlets; waterout+OpenChannel.
undziabundzia is offline   Reply With Quote
Old   November 7, 2015, 09:05
Jordi Pina
jpina is on a distinguished road
I don't really understand the boundary conditions that you are using, if you specify me them, I might be able to help you.
jpina is offline   Reply With Quote
Old   November 10, 2015, 11:24
Jakub
Hey !
Very sorry for late.
Here is my setup i attachment.
Old   November 10, 2015, 15:07
Jordi Pina
Why implicit method?
Is your mathematically necessary time step much lower than the physical time step that would give you enough information?
Old   November 13, 2015, 20:00
Jakub
I would like to see something like this http://www.tafsm.org/PROJ/FSF/cylflow2.jpg , how to make it ? In that case, i will change simulation for explicit and make biger time step size.
two phase flow vof fluent
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
air into box filled with water, outflow for water at bottom dieterdanger Fluent Multiphase 0 July 16, 2015 17:11
Air-water flow (VoF). Need help :( Luke1984 FLUENT 6 October 19, 2009 10:59
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
