Negative Volume - apprentice
Old   November 4, 2015, 22:08
Unhappy Negative Volume - apprentice
Vermont
madboy19 is on a distinguished road
Hello Masters,
I have project for my school that I had to simulate Wankel Motor. I am dealing with it like 7 days already. I didnt understand anything about Dynamic Mesh there is no good tutorial for me.
My problem is
Error at host: Update-Dynamic-Mesh failed. Negative cell volume detected.
Warning: non-positive volumes exist.
Error at Node 0: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error at Node 1: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error at Node 2: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error at Node 3: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error at Node 4: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error at Node 5: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error Object: #f
I learned UDF and when I press "Display Zone Motion" Rotor is rotating very well but when I was press "Preview Mesh Motion" , it gives that errors.
I am attaching my project. I will happy if somebody can help me because my time is limited.
(Without Dynamic Mesh Everything works fine and I can get result from it. But when I use Dynamic mesh and change my rotor - wall to Rigid body with UDF I cant get nothing.)
I couldnt attach my project.
Here is the Link
sihirdarrehberi.com/ansys/wankel.zip
madboy19 is offline   Reply With Quote
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 06:06
[ICEM] negative sector volume adam2008 ANSYS Meshing & Geometry 0 August 9, 2014 01:24
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
remeshing due to negative volume error Doginal CFX 1 August 21, 2011 22:50
