IDEAL GAS: not fulfilled even though set up?
Old   November 2, 2015, 09:31
Default IDEAL GAS: not fulfilled even though set up?
Gergö Schmidt
Fettmon is on a distinguished road
Hi everybody!
My aim is to simulate pressure equalization in inviscid air (density: ideal gas; Cp = 1004.9 J*K^-1*kg^-1; M = 28.966 g*mol^-1).
Therefor I patch 2 different regions with 2 different initial pressures. I have obtained converging results only with a density-based solver and I had chosen an explicit transient formulation with CFL=0.75 for starting.
My continuity, velocity and energy residuals are nicely declining during calculation, BUT when I calculate my ideal gas resiudal with
Absolute Pressure-R/28.966[g mol^-1]*Total Temperature*Density
I obtain residuals up to 30% of the local absolute pressure. This is a problem, because I'd like to comprare the results with ideal analytic solutions.
My questions are therefore:
1) Is my way of calculating the ideal gas residual (see expression above) correct?
2) If 1) is yes, what can I do to get results which are more consistent with the ideal gas law?
Thank you and kind regards!
Gergö
Fettmon is offline   Reply With Quote
Old   November 2, 2015, 10:26
Post
Rahul
raghulvr is on a distinguished road
Firstly,why are you choosing transient simulation for solving the problem?
There is no need for including time-based simulation here.Just try with steady stste simulations.That might help you out!
raghulvr is offline   Reply With Quote
Old   November 2, 2015, 11:02
Gergö Schmidt
Thank you for replying, Rahul!
The pressure equalization I want to simulate shall take place in a shock tube and I am interested mainly in the properties (velocity, pressure difference, shape of face etc.) of the generated shock wave. Rarefraction waves and their reflections are of interest, too. I'd not be able to examine the waves, if I wouldn't use transient formulation.
Old   November 3, 2015, 08:03
Gergö Schmidt
Problem solved. Question 1) has to be answered with 'No', because the variable Temperature (static temperature) is needed instead of Total Temperature (stagnation temperature), ergo the correct expression is
Absolute Pressure-R/28.966[g mol^-1]*Temperature*Density
which is almost zero everywhere in my simulation. Which is super
Old   November 3, 2015, 08:32
Smile
Rahul
Thank you mate! Am also new to CFD.I am trying to gain as much knowledge as i could in the area of CFD.Also thanks for sharing your experience with me
explicit dynamics, ideal gas, pressure equalization, residuals
Ideal gas law and incompressible flow Nick R Main CFD Forum 13 May 27, 2019 15:38
Ideal Gas Mixture, non reacting Ancioi OpenFOAM Running, Solving & CFD 5 April 12, 2013 08:10
air ideal gas in CFX Pre wangy1767 CFX 9 October 1, 2012 08:55
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Problem using ideal gas mark FLUENT 3 November 29, 2004 17:40
