October 29, 2015, 11:45 |
Iron Ore Drying Process (Multiphase)
WALI HASAN
Rep Power: 13 |
Dear CFD Analyst,
I am doing a project work in drying process of iron ore pellet using commercial software ANSYS fluent but I am facing convergence issue in it. The nature of the problem is described in Fig.1. The following are the steps that I followed for the modelling of the same. Pressure based solver Transient analysis Eulerian method = no. of phases =4 (air, liquid, ore, vapor) Turbulence model = kappa omwga SST Energy equation =ON Primary phase =air, Seconday phases= liquid, ore and vapor Interaction= phase change = liquid to vapor Drag : Schiller naumann Fluid 1: Porous zone : Porosity 0.315 Under mixture tab Heat transfer : thermal Equilibrium model : solid material : ore Direction vector X =1, Y=0 Under air phase only Viscous resistance = 3.33e +12 for both direction Inertial Resistance = 1470000 for both direction While for the rest of the phases no resistance values are applied, and applying fixed values of 0m/s for X and Y under fixed tab this is only for the ore phase. Boundary condition: Inlet: velocity inlet, Outlet : outflow, top and bottom : symmetry, ore surface : interior, fluid 1 and 2 region is also interior Solution methods: Scheme : phase coupled SIMPLE Gradient : least square cell based Momentum, volume fraction, turbulent kinetic energy, Specific dissipation rate : First order upwind, Transient formulation: First order implicit Regions Adaption is used for defining the volume fraction Firstly for some time, the simulation is performed without the volume fraction shown in Fig.2 i.e Solution control> equation > Select only flow, turbulence and energy. For this method the solution is well converged after some iteration. (Fig.3) Now , the situation where I am stuck right now when I select the volume fraction (fig.4) after some time of the simulation, to determine the variation of volume fraction inside the ore at this time the solution is not converged it shows: “v-ore residual is in the range of .9912” (fig.5) Please help me how to resolve the issue. The paper that I have used for the validation purpose: Simulation of convective drying of a cylindrical iron ore pellet Anna-Lena Ljung and T. Staffan Lundstro¨m Division of Fluid Mechanics, Lulea° University of Technology, Lulea° , Sweden, and Kent Tano LKAB R&D, Malmberget, Sweden Regards Wali |
The fl process could not be started because of UDF | majid_kamyab | Fluent UDF and Scheme Programming | 6 | December 15, 2015 08:42 |
Iron Ore Drying Modelling | wali | FLUENT | 2 | August 28, 2015 09:38 |
drying rate simulation for iron ore pellet | wali | Fluent Multiphase | 0 | July 9, 2014 17:08 |
Drying process | mehdimoradi. | FLUENT | 0 | July 16, 2013 04:26 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 14:11 |
