Natural convection energy convergence problem |
October 27, 2015, 05:23 |
SANOOJ SIDDIKH
Rep Power: 10 |
Hi....
Am working now on a Natural Convection of Vertical fin arrays(vertical plate, horizontal fin surface) problem.The thing is that my Energy Equation isn,t converging!... |
October 27, 2015, 07:19 |
Devesh Baghel
Rep Power: 17 |
Can you please elaborate more on problem statement/case setup ?
Devesh |
October 27, 2015, 11:15 |
Lucky
Rep Power: 66 |
Is it diverging or is it not converging?
Assuming you did everything correctly (beautiful mesh, correct boundary conditions, strong initial guess, etc). Lowering the urf to 0.5 for energy helps if it's a coupling problem that's preventing your solution from converging. Are you using boussinesq, ideal gas, or real gas? An ideal gas / real gas needs a very good initial guess or it's most likely to diverge on the first iteration. What about other properties? Are they constants or fully implicit? Anyway there's not enough information given to have any meaningful discussion of what is occurring. |
October 27, 2015, 11:49 |
#4 | |
SANOOJ SIDDIKH
Rep Power: 10 |
http://www.cfd-online.com/Forums/att...1&d=1445964513 please check this in this i have given a,b,f as air inlets...with velocity 0.1m/s.heat flux was given at fin base plate and pressure outlet on faces e and c. here gravity waz on at 9.81m/s2 used bussiness approximation,solution method- SIMPLEC,pressure-body weighed and momentum,energy as power law... my energy is nt converging.....do help me.. |
October 27, 2015, 11:55 |
SANOOJ SIDDIKH
Rep Power: 10 |
please check this....
in this i have given a,b,f as air inlets...with velocity 0.1m/s.heat flux was given at fin base plate and pressure outlet on faces e and c. here gravity waz on at 9.81m/s2 used bussiness approximation,solution method- SIMPLEC,pressure-body weighed and momentum,energy as power law... my energy is nt converging.....do help me.. Capture.PNG |
October 29, 2015, 07:23 |
Devesh Baghel
Rep Power: 17 |
Can you please post convection current contour plot ? Did you try with lower URF of energy as Lucky suggested ? Also look for, top surface (Pressure-outlet) should bound the flow field in current domain. |
Natural convection, problems with total energy balance | MdoNascimento | STAR-CCM+ | 0 | March 13, 2014 12:15 |
Natural Convection - Problem in achieving converged solution | howhs | FLUENT | 2 | August 28, 2013 10:51 |
Pls help imp!! Convergence of natural convection model | laura_c | Main CFD Forum | 2 | May 15, 2013 08:03 |
Problem with natural convection | claudia.h | FLUENT | 2 | July 3, 2012 03:10 |
Natural convection problem in CFX 11 | Willy | CFX | 2 | May 23, 2008 23:12 |
