UDF for a time varying temperature boundary conditions |
giuseppe lombardo
Rep Power: 11 ![]() |
I'm VERY new to Fluent and I'm attempting to write a UDF that will make the temperature at a wall a function of time. I've never programmed in C before either so I'm having some trouble getting the correct UDF. I'm working on an aluminum casting made from a sand casting process. I decided to use a specimen, as a representative part of my process, which has been reduced in geometry to its initial gauge length. As a result I have, as can be seen from the screenshot below, a cylindrical aluminum piece surrounded by a cast iron chill and the sand mould. What I want to figure out is how to do the simulation, starting by put the boundary conditions, passing through the mesh setting and finishing up with the computational setup. I need to put three different temperature profiles on three boundary conditions as below: 1. between the metal and the chill 2. between the metal and the sand mold 3. between the chill and the mold (three highlighted surfaces) How can I define a correct code for these boundaries? Thanks in advance! |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Boundary conditions for time varying crosswind | krembil | FLUENT | 1 | April 10, 2015 05:44 |
UDF for a time varying temperature | majidmng | Fluent UDF and Scheme Programming | 0 | November 21, 2013 02:38 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
