Chemical Reactions usingRate Exponent (Eddy-Dissipation) |
October 19, 2015, 06:20 |
Pawel
Dear Colleagues!
I'm trying to add chemical reaction in Fluent using Eddy-Dissipation in Species Transport Model. After adding the reactants and products of the reaction, the "stoichiometric coefficients" and the "rate exponents" are demanded. About "stoichiometric coefficients" everything is clear. But what is the "Rate exponent"? Any synonims? How're they being calculated and which data is required. I've looked through corresponding chapter of Ansys tutorial, but unfortunately this rates are described quite briefly. Does anyone has any ideas? A similar question about the "Mixing Rate". What's it and how it's calculated? Thank you for the attention. |
chemical reactions, eddy-dissipation, mixing rate, rate exponent, species transport model |
eddy dissipation model: combustion doesn't occur | roukaia | FLUENT | 2 | November 18, 2020 10:23 |
How to use Eddy Dissipation rate only When using Finite rate/Eddy Dissipation model | Dziyad | FLUENT | 2 | February 19, 2014 17:25 |
Chemical reaction using Eddy Dissipation Model in FLUENT | hyperflow | FLUENT | 5 | June 11, 2012 04:54 |
eddy dissipation model: combustion doesn't occur | roukaia | FLUENT | 0 | December 24, 2011 09:10 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
