October 18, 2015, 12:32 |
Why the solution could only be converged in
Peter Aestas
Rep Power: 13 |
In my case, i solved two UDS and flow.
Density method was used, the solution control is like this: QQ??20151018232814.jpg 2ddp solver was used when i set the discretization method of flow as first order upwind, the solution could converged quickly. But when i change it to second order upwind(at about 921 step), after some iteration error quick occured like this: 2222.jpg ================================================== ========== time step reduced in 2 cells 1115 2.0238e+00 2.5777e-01 1.9400e+00 1.9950e+00 3.0582e-05 1.9039e-06 0:00:05 805 time step reduced in 2 cells absolute pressure limited to 1.000000e-002 in 2 cells on zone 2 1116 5.6257e+00 7.1932e-01 5.4224e+00 5.5522e+00 1.2272e+00 7.9264e+09 0:00:04 804 time step reduced in 1145 cells absolute pressure limited to 1.000000e-002 in 7 cells on zone 2 absolute pressure limited to 5.000000e+012 in 30 cells on zone 2 temperature limited to 5.000000e+012 in 86 cells on zone 2 Error: Floating point error: overflow Error Object: () ================================================== ========= i don't know how it happens and how to avoid this,could someone help me? P.S. how much difference can the two method cause to the results? |
October 18, 2015, 12:43 |
Danny
Rep Power: 11 |
I have had this happen to me before when switching between 1st order and 2nd order upwind using the density solver but without UDFs. I solved the problem by reducing the Courant number prior to the switch and letting the simulation run for some time before ramping up the Courant number slowly. Try this to see if it works.
October 18, 2015, 22:57 |
#3 | |
Peter Aestas
Rep Power: 13 |
But I reduced the Courant number from 1 to 0.1 or even 0.01 prior to the switch, but the error still occurred.... Sometimes when i switch 1st order to 2nd order error like this occurred: ============================ 862 1.9177e+00 3.1486e-01 1.7713e+00 1.8499e+00 3.7691e-05 3.2944e-06 0:00:01 99732 863 3.5531e+00 5.7955e-01 3.2954e+00 3.4302e+00 9.5398e-05 4.0079e-06 0:00:01 99731 864 1.1012e+01 1.8027e+00 1.0253e+01 1.0635e+01 4.3546e-03 1.2504e-04 0:00:01 99730 time step reduced in 2 cells 865 6.5079e-01 1.5483e-01 6.5359e-01 6.3682e-01 3.7083e-03 2.9342e-02 0:00:01 99729 866 2.9763e+00 -1.#INDe+00 2.4637e+00 -1.#INDe+00 1.#QNBe+00 1.#QNBe+00 0:00:01 99728 reversed flow in 18 faces on pressure-outlet 5. ! 867 solution is converged 867 -1.#INDe+00 -1.#INDe+00 -1.#INDe+00 -1.#INDe+00 1.#QNBe+00 1.#QNBe+00 0:00:00 99727 ============================ |
October 19, 2015, 00:32 |
#4 | |
Peter Aestas
Rep Power: 13 |
However, i changed Courant number to 0.01 before switching discretization of Flow to 2nd order upwind, and the error still exists ====================== 432 2.4575e-01 2.2115e+00 2.5251e-01 2.5380e-01 0:00:48 99620 433 2.4643e-01 2.2096e+00 2.5320e-01 2.5450e-01 0:00:39 99619 ! 434 solution is converged 434 -1.#INDe+00 -1.#INDe+00 -1.#INDe+00 -1.#INDe+00 0:00:31 99618 ========================== 3333333333333.jpg |
October 19, 2015, 10:19 |
Danny
Rep Power: 11 |
When I had this happen to me in the past, it was caused by a meshing issue. I had several skewed cells that prevented convergence using second order upwind. I switched to a structured mesh which gave me high quality cells and the solution converged just fine. Can you report the minimum quality of the mesh that you have and post a picture of your mesh so that we can diagnose the problem better?
October 19, 2015, 10:29 |
#6 | |
Peter Aestas
Rep Power: 13 |
========================= Grid Check Domain Extents: x-coordinate: min (m) = -5.000000e-003, max (m) = 5.000000e-003 y-coordinate: min (m) = 0.000000e+000, max (m) = 1.000000e-002 Volume statistics: minimum volume (m3): 2.506945e-007 maximum volume (m3): 2.770834e-007 total volume (m3): 9.500001e-005 Face area statistics: minimum face area (m2): 5.000000e-004 maximum face area (m2): 5.555556e-004 ========================= > grid /grid> quality Grid Quality: Applying quality criteria for quadrilateral cells. Maximum cell squish = 1.22896e-003 Maximum 'aspect_ratio' = 1.53168e+000 i know little about mesh, in my case, first i meshed all the edges by interval size, then created the mesh of face 4444444444.jpg |
October 19, 2015, 10:39 |
Danny
Rep Power: 11 |
What is it exactly that you are trying to model? I don't see any geometry in this picture. Is this flow over a flat plate?
October 19, 2015, 10:42 |
Peter Aestas
Rep Power: 13 |
No, i am trying to solve a plasma problem in vacuum condition, the lower edge is cathode(pressure-inlet), upper is anode (pressure outlet), and the sides are set as walls or far field to simulate free diffusion.
October 20, 2015, 00:28 |
#9 | |
Peter Aestas
Rep Power: 13 |
1.png I found two problems: 1. The previous model with thin grid mesh density, could be directly converged with 2nd order discretization of Flow after initialization. But this new model would become divergence. The way to use 2nd order discretization is, use 1st order first until convergence, then switch it to 2nd order(without any other change including Cournt number) 2.png 2. I compared the pressure and other parameters, the two discretization method greatly affected the results. 1st order 3.png 2nd order 4.png This means i have to figure out how to use 2nd order without any error in the model i posted... |
October 20, 2015, 01:46 |
#10 |
Devesh Baghel
Rep Power: 17 |
1. Is it the result of stabilized flow field ? 2. what is residuals limit looking for convergence i.e. 10^-3 ? If yes, are you switching over to 2nd order descritizatio once you reached 1st order convergence. 3. Results shown are till 1800 iterations or more ? since 2nd order descritization impose tight calculation to stabilze the flow field, also depends on good guess of initialization. Pressure contour reflects that, pressure loop is travelling towards outlet, I think you should run for more iterations by monitoring some scalar\ flow parameter for better convergence. |
October 20, 2015, 04:47 |
#11 | |
Peter Aestas
Rep Power: 13 |
1. Yes, it is a steady case of the flow. 44444444444444444444444.jpg 2. Yes, except i set the residuals limit of UDS0 to 1e-6 123123123.jpg And it is after the solution reached 1st order convergence that i switching over to 2nd order descritization 3.Result stopped at about1300 iterations, after i switch to 2nd order, the residuals quickly reached the criteria again. The expected result is closer to 2nd result (the maximum pressure center is not at the upper outlet boundry but near the center of the geometry.) And my main problem is, 2nd order may not converge regarding different cases (like the case i post in #1 with declining edge of the right and left sides). (Since 1st order can always converge) I don't know why. |
October 20, 2015, 05:31 |
#12 |
Peter Aestas
Rep Power: 13 |
My email address is hellofdy@gmail.com, i am looking forward to your reply and help, my friends.
solution is converged but a problem | flow_CH | FLUENT | 9 | June 2, 2020 10:34 |
simple solution converged in 9 iterations? | Gabbee90 | OpenFOAM Running, Solving & CFD | 4 | January 29, 2019 22:04 |
Solution not converged for supercritical annular flow | K.Saikia | FLUENT | 0 | November 14, 2014 03:29 |
solution is not getting converged | Nijanthan | FLUENT | 5 | July 25, 2013 02:42 |
New sixDoFRigidBody BC working with laplaceFaceDecomposition | Ya_Squall2010 | OpenFOAM Running, Solving & CFD | 13 | April 17, 2013 03:04 |
