Negative pressure & function inlet
Old   October 18, 2015, 07:19
Default Negative pressure & function inlet
BarDror is on a distinguished road
Hi!
I don’t have much experience using FLUENT, so I faced some problems and that’s why I’m seeking your help.
First problem:
I am modeling the process of the stencil printing. I would like to get the pressure distribution on the surface of the stencil. I made the geometry as you see on fig1. The bottom line represents the stencil; the skew line the printing knife, and the curve is the phase boundary of the air and the printing material.
It’s a steady state 2D problem, I made it pressure-based type, and the viscous model is laminar, the others are not used.
I gave the stencil a moving wall boundary, and the knife is staying still during the simulation. ( I made it the same way using CFX and I got the theoretical results, depending on some literature)
My problem is I get only negative pressure! I don’t really no what to do with that, someone said it can be some solver setting problem, but I thought it would be better asking you. Do you have any ideas, how to make it work?
My second problem:
It’s a transient pipe filling. The geometry has 2 walls, an inlet and an outlet. The pipe filled with air at the beginning. I set a constant pressure inlet boundary, and water fills the pipe time step by step. It works. But I would like to set a function as an inlet boundary. And that’s where I stacked. Could you help me with that, or give some hint where to start looking for?
Thank you for any kind of help!
BarDror is offline   Reply With Quote
function, inlet, negative pressure
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
Pressure Inlet: question about total pressure I-mech FLUENT 0 July 13, 2014 06:38
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
