October 16, 2015, 14:18 |
Issue: Nozzle Discharge Coefficient
Hey CFD experts,
I am having trouble predicting the discharge coefficient (Cd) for a standard 2.5mm Nozzle (or just a simple orifice). The nozzle Cd, defined as the ratio between the actual mass flow rate and the theoretical mass flow rate, has to have a value less than 1. In my latest simulations, I am getting values as high as 1.5 which makes no sense. The model conditions are: Fluid: Water Energy turned off Turbulence Model: k-w SST Throat Size: 2.5mm Pressure Based – Coupled solver 2nd order Psuedo-transient Pressure In: 2400psi Pressure Out: 0psi Operating Pressure: 1atm I know that the true Cd=~0.99 and I was able to get this in the past. Now I am getting values of 1.5 and it makes no sense. Does anyone have thoughts on this? Thanks, Liam |
October 17, 2015, 09:53 |
Danny
Rep Power: 11 |
Can you post a picture of your mesh? It might be a meshing issue. Also have you tried to refine your grid to see if your Cd value changes?
February 25, 2017, 15:45 |
DavidB
How did you manage to plot the discharge coefficient? On fluent there isn't an option for it.
February 25, 2017, 17:04 |
Lucky
Rep Power: 66 |
cfd, discharge coeff, issue, nozzle |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
[ICEM] Troubleshooting Wall Inflation Issue for a 2D Nozzle | cfmontes | ANSYS Meshing & Geometry | 1 | May 14, 2015 18:13 |
Need ideas-fuel discharge system | Jan | Main CFD Forum | 0 | October 9, 2006 04:27 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
