Inlet boundary condition for transitional turbulence models |
October 13, 2015, 09:05 |
RM1358
Dear all,
I would like to use a transitional turbulence model such as Transitional-SST for an internal flow simulation. The flow is developed through a channel connecting a high pressure and a low pressure chamber. As the flow is not turbulent at the inlet, which values should I set for the inlet turbulence intensity and turbulence viscosity? Is it OK if I set them nearly zero, i.e. ~1e-6? Regards |
October 14, 2015, 01:28 |
Lucky
Rep Power: 66 |
Yes. You may want to use intensity & length scale if it is more convenient.
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 09:56 |
transitional inlet boundary condition | kamp | CFX | 1 | June 21, 2006 12:08 |
