ray-tracing solar load vs DO radiation model
Old   October 9, 2015, 11:00
Question ray-tracing solar load vs DO radiation model
Nima
nima_nz is on a distinguished road
Hi
I'm confused in using ray-tracing solar load model and DO radiation model.
When we use the ray-tracing solar load model to simulate the solar load on the semi-transparent wall (eg, glass window), If DO radiation model enabled, in boundary condition menu at radiation tab, we should specify the value for Irradiation; If determine a value for irradiation there after solution converged, in the results, it seems the software affects two irradiation separately in the solution (one from solar load and another from irradiance which determined at boundary condition). What should we do in this problem? An idea is finding transmitted visible irradiation from ray-tracing and after that disable the solar load model and determined that value in the boundary condition's radiation tab.
Thanks for your help.
nima_nz is offline   Reply With Quote
Old   October 15, 2015, 15:06
riahi
riahi1143 is on a distinguished road
hello nima
are you working on concentrated solar energy or flat plate?
riahi1143 is offline   Reply With Quote
Old   October 16, 2015, 05:53
Nima
You know, I want to model the solar energy penetrated through glazing in the building, but it doesn't work properly.
Old   November 21, 2015, 05:35
Johnny
Johnny leow is on a distinguished road
Hello, Nima.
Are you working and analysis the concentrated solar energy or flat plate? I am also...But i do not get any idea of it, as I am new beginner of Ansys. Can you sharing some information with me?
Johnny leow is offline   Reply With Quote
Old   August 26, 2021, 10:22
Default solarload
Su xin
Su xin is on a distinguished road
Hello!
Use solarload in chtmultiregionfoam and select sundritracking. Why does the temperature rise again until the sun sets completely?
Su xin is offline   Reply With Quote
Old   June 26, 2024, 01:32
Default solar load for pv cooling
Raza Saleem
issaleem is on a distinguished road
Hi! i am recently working with the solar radiation for cooling the pv panel
i am using the do radiation model when i apply the boundary condition and initialized it the maximum solar irradiation is 800 approximately according to the latitude and longitude. but when i plot the incident radiation the value starts from 1900 w/m2. the value need to be below 850 w/m2 according to our experimental value.
can anyone have an idea about that. i will appreciate any updates thank you in advance.
issaleem is offline   Reply With Quote
Solar radiation model Min Siemens 2 August 31, 2018 09:04
Solver refuses to run: Monte Carlo Radiation Model Zaphod'sSecondHead CFX 9 February 14, 2017 10:20
fresher in heat transfer and solar load model itsme_kit FLUENT 4 January 11, 2016 13:12
Solar load model and ambient temperature itsme_kit FLUENT 0 January 31, 2014 19:18
solar radiation load rahulrahul155 Main CFD Forum 6 November 20, 2009 00:43
