Discrete Phase Modelling Mass Flow Rate
Old   October 8, 2015, 07:22
Default Discrete Phase Modelling Mass Flow Rate
Jeeloong is on a distinguished road
Dear All,
I have a pipe. Given that they have symmetry plane. I will only model half of it. (Sacrifice some accuracy).
I wish to inject particle at second inlet. However, I am quite confused with how the mass flow rate and velocity works.
I know continuity equation said that mass_flow_rate = densityxvelocityxarea =pAv = m_dot
or m_dot = p_v_dot(volume_flow_rate)
Let said I want to introduce 1 litre/min (1x10-3/60)
Let say my density of fluid is 1000 m^3/kg
Then will give me mass_flow of =0.0166 kg/s right?
For a given area let say my pipe is symmetry which means my injection will be (half circle area), if I *tick* scale with area. Which means the flow rate will be double? Since I apply symmetry instead of full circle area.
how about the velocity? The problem is droplet is not a continuum. how I work it out with the pAv formula?
Can someone explain to me slightly so I can apply right flow rate to my system.
Thanks
Kind Regards,
Jee
Jeeloong is offline   Reply With Quote
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Mass flow rate boundary condition with negative values ashtonJ CFX 3 November 26, 2014 06:21
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
Mass Flow Rate student87 CFX 4 January 2, 2010 05:45
mass flow rate of a dispersion phase Paul FLUENT 1 February 26, 2002 00:19
