Rep Power: 13 ![]() |
Dear sir,
I am a PhD student & my research topic is scale up of aerobic fermenter. I am doing lab scale experimentation for fermentation kinetic study. Simultaneously I am learning the ansys fluent for CFD study. Scope of my PhD is work is to combine reaction/fermentation kinetic model with the CFD model to find out the optimum process parameter & scale up of bio-fermenter. I am new user of Ansys fluent. For initial tutorial purpose i wanted to study the mixing behaviour in single phase mixing tank. I have created geometry in designer modeller as shown in attachment. I have kept tank & rotor ( with impeller) as a two body part for geometry. In problem set up i have considered transient case setup and Tank & rotor fluid as water. In cell zone condition rotor is defined in frame motion with 15 rad/sec as shown in attachment. Outlet at top is defined as pressure outlet in boundary conditions. These are the only inputs i have given in cell zone & boundary condition. After run calculation i got the residual graphs as shown in attachment. I faced problem when i started the post processing. I am able to see the contours & streamline only for rotor region & tank region is empty as shown in attachment. I am not able to analyse what went wrong with solution as i am not bale to see contours in tank. I have follow the sliding mesh mixing tank tutorial steps ( from you tube) for this case (except cell zone where i have selected Frame zone motion). Also i am attaching the velocity magnitude results. I have attached some snapshot of my case with this thread & remaining snapshots will be uploaded in another thread. Please help me to understand, which parameter should i checked to analyse the mixing behaviour? How can i say that my case is run successfully? Is there any other literature available on mixing tank study? May be these are the silly questions but i am facing a lot difficulties in this. Please help me out as I am stuck on this for long time. |
Please can any one help me?
[ANSYS Meshing] mesh a mixing tank | wemendibe | ANSYS Meshing & Geometry | 32 | March 20, 2015 14:33 |
[DesignModeler] Modelling mixing tank using MRF approach | Natali | ANSYS Meshing & Geometry | 0 | March 17, 2015 06:26 |
mesh of mixing tank in gambit | wemendibe | ANSYS Meshing & Geometry | 1 | June 3, 2013 01:32 |
Particle tracking in Mixing tank | zhang.limin | FLUENT | 0 | November 12, 2010 20:23 |
Modelling mixing tank using MRF | Adi | FLUENT | 6 | November 4, 2009 00:28 |
