September 30, 2015, 05:00 |
Particle injection not tracked DPM
Sujay
Rep Power: 16 |
Dear Friends,
I am injecting inert solid particle which do not have effect on continuum fluid using single or group type injection but not a single particle is added. I am specifying points which positioned at the inlet, diameter, velocity, mass flow rate and using standard parcel. Injection is happening if i changes this to surface type but always add 300 particles in each time step of DPM irrespective of mass flow rate and particle dia. ? Why this is happening in both these cases ? Thank you, Sujay Patil |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
multicomponent particle injection in DPM | Ning | FLUENT | 0 | December 23, 2008 09:23 |
UDF for particle injection in DPM model | sohail | FLUENT | 0 | July 22, 2008 11:12 |
Particle injection in DPM | Zenith | FLUENT | 1 | March 17, 2007 05:33 |
