September 25, 2015, 14:52 |
modeling cross flow problem in fluent
Khalid Baker
Rep Power: 17 |
I attempted to model cross flow of hot fluid (water) and cold fluid (air) into a finned 3D duct with fins like show in picture attached. The fins located at air side and there are three air inlets, three air interiors and three air outlets and the air flow in the axial direction while water enter from the top and exit from the bottom. I set the air inlet with temperature 300 K and water inlet at temperature 450 K and I used velocity inlet at both water and air when i run the case a reverse flow happen from all outlets and in spite i get convergence at last but temperature contours be equal to 300 at both fluids without any change? may somebody tell me what problem in my settings? knowing that
the duct length and height 16 mm and depth 8 mm?? regards k.baker |
Modelling Slug Flow in ANSYS Fluent VOF. | OliverMechEng2208 | Fluent Multiphase | 1 | March 18, 2015 06:45 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
Modeling unsteady multiphase flow in porous media - convergence problem | Vaibhav Kumar | Main CFD Forum | 1 | July 22, 2012 05:32 |
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 02:22 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 07:12 |
