Concentration gradient
Old   September 25, 2015, 08:52
Default Concentration gradient
Bruno Machado
Bruno Machado is on a distinguished road
Hi everyone,
My PhD project involves the simulation of a fuel cell. I built a model using UDF and it works ok. The reason it is ok is that my species concentration gradient of species is very small within the "flow channel/gas diffusion layer/catalyst layer".
I am considering a (compressible) mass-flow-inlet boundary condition where I define the mass flow rate, temperature, mass fraction of species. In the outlet, a pressure-outlet boundary is defined and backflow temperature and species are defined as well. Is this the best boundaries for this case?
Does anyone worked with UDF and reactions? Anyone had the same problem?
Anything that could help me fix this issue are more than welcome.
Thanks all.
Bruno Machado is offline   Reply With Quote
Old   October 12, 2015, 05:39
maverick123 is on a distinguished road
@ Bruno : As a single fuel cell channels c/s is very very small, laminar flow considerations would be better.
maverick123 is offline   Reply With Quote
Old   October 12, 2015, 06:42
Bruno Machado
Dear Maverick, thank you for your response.
I am considering a laminar flow in the flow channel. Even when considering a single fuel cell channel, the inlet is adjusted to change accordingly to the stoichiometric ratio for anode and cathode. In literature there are many studies where, even for a single channel, the concentration difference between inlet and outlet changed considerably( let's say about half for a stoichiometric number 2).
What I see now is that my electronic and ionic potential are very close to each other, so the overpotential is very small (it is bigger near the interface of the catalyst with the membrane and goes near 0 through the catalyst layer). Any comments on that? I am simulation an Anion Exchange Membrane Fuel Cell and my equations for electronic and ionic potential potential are:
-grad(diff_ele.grad(ele_pot)) = S_ele
S_ele = - j_a (Butler Volmer) if anode catalyst layer
S_ele = j_c (Butler Volmer) if cathode catalyst layer
-grad(diff_ion.grad(ion_pot)) = S_ion
S_ion = j_a (Butler Volmer) if anode catalyst layer
S_ion = - j_c (Butler Volmer) if cathode catalyst layer
Anything comes to your attention?
Any help or comments are welcome.
Regards
Old   October 12, 2015, 07:56
Hi Bruno,
You are quite right that there will considerable difference between H2 concentration on Anode side (I checked for Proton Exchange Membrane Fuel cell) . Are you using Fluent Fuel Cell Module ? You said, you are simulating Anion Exchange Membrane Fuel Cell. Is it alkaline AEMFC ?
Best Regards,
Old   October 12, 2015, 08:19
Bruno Machado
Hi Bruno,
Best Regards,
Hi Maverik123,
I am not using the Fuel Cell module, I built an entire code to simulate an alkaline AEMFC.
Old   October 12, 2015, 08:47
Hi Bruno,
Apart from the two potential equations, what are the other equations?
You may need other Scalar Transport Equations as well. (Honestly speaking I don't have any experience with alkaline AEMFC.)
In case on PEM FC , one need Scalar Transport Equation for Electric Potential, Protonic Potential, Water Content and water Saturation.
Best Regards,
Old   October 12, 2015, 09:21
Bruno Machado
Hi Bruno,
Best Regards,
Thanks for your answer.
Yes, I do have 4 scalar equations for electronic and ionic potential, water content and water saturation (liquid water). Both water phases equations seems to be working well, with values as expected. I only mentioned before the electronic and ionic because, apparently, the problem is that both values are closer to each other, and I am expecting a bigger gap (bigger overpotential -> bigger reaction rate -> bigger species gradient).
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
Generating concentration gradient by fluent ashish FLUENT 2 September 9, 2015 06:13
UDF to Access Wall Normal Concentration Gradient Daniel Tanner Fluent UDF and Scheme Programming 4 February 18, 2015 15:35
concentration gradient Juan Phoenics 1 February 10, 2006 14:38
finding concentration gradient hatta FLUENT 2 December 21, 2004 12:31
