Sliding mesh for translational relative motion between solid and fluid |
September 23, 2015, 16:42 |
shashank mishra
Rep Power: 15 |
Hello everyone,
I am trying to model a moving train in a low pressure tunnel. The train is moving at some finite speed and at inlet, I know total pressure of wind. In order to simulate, the transnational relative motion between solid (train ) and fluid ( air ) zones, I tried using sliding mesh technique. After creation of interfaces, I imposed a certain x velocity to the solid zone. Since, I have total pressure at the inlet as a known quantity, I cannot simulate with imposing train velocity to air in opposite direction ( as would have been done in wind tunnel) as this will changed the total pressure. I have used sliding mesh before for rotating case but this time when I tried with a very basic geometry ( a box immersed in fluid ), it didnt work. So, does it mean that I need to use dynamic mesh and specify cg motion for solid zone to simulate this problem. Attached is an image for mesh motion which is totally absurd. Thanks |
December 27, 2019, 11:50 |
Pallavee Dhekne
Rep Power: 7 |
Have you solved your problem? I am also facing same issue. Does sliding mesh works for translational motion of solid in fluid ?
April 12, 2024, 18:27 |
Sebastian
Hello, have you solved the problem?
dynamic meshing, fluent 14 to fluent 15., sliding mesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 10:33 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
External management of solid motion (using dynamicmesh) | maxou1993 | Main CFD Forum | 0 | July 28, 2015 12:37 |
