calc drag force
Old   September 22, 2015, 10:06
Default calc drag force
hilla tor
hillat is on a distinguished road
I am trying to calculate the drag force due to pressure on part of the wall (not all the wall) who can I done it? I also try to calculate it by F=sum(P*n)
thanks for the help
hillat is offline   Reply With Quote
Old   September 22, 2015, 23:37
Lucky
It's easiest if you split your surfaces so that the desired region is its own part.
Don't forget to also integrate the wall shear stress to compute the total drag force.
Old   September 23, 2015, 01:21
Default it's possible to split
hilla tor
the surface (line) at fluent?
Old   September 23, 2015, 09:37
Default when I am tring to split
hilla tor
my surface at fluent I use
mesh-> separate?
Old   March 13, 2018, 02:46
Jennifer Von
Jennifer Von is on a distinguished road
I think it means split your surface before you mesh it.
Jennifer Von is offline   Reply With Quote
drag force, monitors
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
FLUENT: how to record drag force at every time step? qiulan FLUENT 4 March 20, 2017 22:22
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Force vectors for drag during sweeping motion aamer FLUENT 0 April 18, 2011 09:17
formula used for drag force? kamma Main CFD Forum 0 April 2, 2010 11:21
