Calculation stop with ansys fluent windows 8
Old   September 21, 2015, 05:59
Angry Calculation stop with ansys fluent windows 8
jbnad
jb pouillard is on a distinguished road
Hi everybody,
I have problem since I instal ANSYS FLUENT in windows 8.
After several time, or iteration ansys fluent crash, with error, f1 process could not started.
I have this problem for little (1millions of cells) and big (15 millions of cells) cas.
with little cas calculation crash after 1000 iteration, with big cas problem after 300 iteration.
My computer is new, i have 32 go of RAM, someone know and fix this problem ?
It's big problem for me because i cant run calculation for a nigth.....
thanks
jb pouillard is offline   Reply With Quote
Old   September 22, 2015, 01:13
Rodlitul awwalin
Susenok1990 is on a distinguished road
Originally Posted by jb pouillard View Post
Hi everybody,
thanks
hi bro,
i advice to change windows 8 to windows 7, because may some not compatible with ansys program. regards
Susenok1990 is offline   Reply With Quote
Old   September 22, 2015, 02:28
Lucky
Which version of Fluent are you using?
The problem is likely an mpi fault. Make sure your Fluent & mpi version are supported in windows 8. To check if it's an mpi error, run in serial mode.
Another reason could be overclocked ram which is unstable.
Old   September 22, 2015, 04:35
jbnad
Hi bros,
Thanks for answer,
Yes I was investigated on this way, problaby they is a problem with win 8.1.
I'm running Ansys fluent v15.0 v15.7 v16, problem appear for each version.
I will check my mpi version and try to run a serial simulation. If it's running in serial without problem, what can i do ?
fluent error f1 process
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
Recent thoughts- Fluent on Linux vs Windows jpo FLUENT 1 May 17, 2012 07:20
Fluent on windows server Shamoon Jamshed FLUENT 0 November 14, 2009 13:32
