September 16, 2015, 07:06 |
PEMFC model with FLUENT
brahim choice
Rep Power: 11 |
Hi, I used the tutorial form Fluent for PEMFC :"Tutorial: Modeling a Single-Channel, Counter-Flow Polymer Electrolyte Membrane (PEM) Fuel Cell ", after complete the geometry and the mesh with Gambit and setup Fluent, the calculation halt with issues as "segmentation signal fault, error of convergence, etc.", need help to understand in the Tutoria model of PEMFC really works.
Sincerelyn, |
September 16, 2015, 07:50 |
Bruno Machado
Rep Power: 13 |
The tutorial works. The segmentation fault error happens when there is some missing information (boundary condition, variables not properly defined in case you used UDF, etc.). Check is all information need is provided and the segmentation fault should be gone.
September 16, 2015, 11:23 |
brahim choice
Rep Power: 11 |
I still have issues to run the tutorial. this is the mesh that I used and the the fluent case data. is there a way to have a working EPMFC model to download?.
June 26, 2016, 04:56 |
Dm Fo
Rep Power: 11 |
I have the same problem with segmentation. Do we solve this error?
June 26, 2016, 09:14 |
A-A Azarafza
Rep Power: 14 |
Hi Friend, Please, be in contact to me for your problem by providing more details..
Regard yours |
June 27, 2016, 04:51 |
Dm Fo
Rep Power: 11 |
I will try to replicate tutorial of PEMFC another one time. First of all, in Fluent 17 (which I use), as well as 16 and 15 versions, I can choose [3] FC and Electrolysis model or [9] PEM FC model. Which model does correspond to tutorial''s model? And what is the difference between them?
June 27, 2016, 04:56 |
#7 | |
A-A Azarafza
Rep Power: 14 |
Hi, The PEMFC model is for the tutorial. FC, and electrolysis corresponds to solid oxide fuel cell and electrolyser (SOFC&SOEC). Regards,
Regard yours |
June 27, 2016, 14:59 |
#8 | |
Dm Fo
Rep Power: 11 |
Finally, following to tutorial I have new error like this: iter continuity x-velocity y-velocity z-velocity energy h2 o2 h2o uds-0 uds-1 uds-2 uds-3 time/iter V_cell = 0.750000 (V) ... V_open = 1.183261 (V) I_anode = 0.182809 (A/cm^2) ... I_cathode = 0.520703 (A/cm^2) ... dI_mea = -0.337894 (A/cm^2) ... dI_stk = -0.337894 (A/cm^2) 1 1.0000e+00 1.0031e-01 9.9029e-01 8.3462e-01 2.5701e+04 0.0000e+00 9.7376e-02 6.1092e-02 8.7309e-12 7.1504e-01 1.0059e+00 1.2889e-07 0:34:19 99 # Divergence detected in AMG for temperature, protective actions enabled! # Divergence detected in AMG for temperature, temporarily solve with BCGSTAB! # Divergence detected in AMG for uds-2, protective actions enabled! # Divergence detected in AMG for uds-2, temporarily solve with BCGSTAB! # Divergence detected in AMG for uds-3, protective actions enabled! # Divergence detected in AMG for uds-3, temporarily solve with BCGSTAB! Warning: Invalid cp (0.000000e+00 J/kgK) for hydrogen at temperature -1.#IND00 K V_cell = 0.750000 (V) ... V_open = 1.163195 ... 1.181110 (V) I_anode = 0.175428 (A/cm^2) ... I_cathode = 0.067200 (A/cm^2) ... dI_mea = 0.108228 (A/cm^2) ... dI_stk = 0.108228 (A/cm^2) Divergence detected in AMG solver: species-0 Divergence detected in AMG solver: species-1 Divergence detected in AMG solver: species-2 Divergence detected in AMG solver: temperature Divergence detected in AMG solver: uds-0 Divergence detected in AMG solver: uds-1 Divergence detected in AMG solver: uds-2 Divergence detected in AMG solver: uds-3 Divergence detected in AMG solver: species-0 Divergence detected in AMG solver: species-1 Divergence detected in AMG solver: species-2 Divergence detected in AMG solver: temperature Divergence detected in AMG solver: uds-0 Divergence detected in AMG solver: uds-1 Divergence detected in AMG solver: uds-2 Divergence detected in AMG solver: uds-3 Divergence detected in AMG solver: species-0 Divergence detected in AMG solver: species-1 Divergence detected in AMG solver: species-2 Divergence detected in AMG solver: temperature Divergence detected in AMG solver: uds-0 Divergence detected in AMG solver: uds-1 Divergence detected in AMG solver: uds-2 Divergence detected in AMG solver: uds-3 reversed flow in 420 faces on pressure-outlet 100. reversed flow in 420 faces on pressure-outlet 101. Divergence detected in AMG solver: species-0 Divergence detected in AMG solver: species-1 Divergence detected in AMG solver: species-2 Divergence detected in AMG solver: temperature Divergence detected in AMG solver: uds-0 Divergence detected in AMG solver: uds-1 Divergence detected in AMG solver: uds-2 Divergence detected in AMG solver: uds-3 Error at Node 3: floating point exception Error at host: floating point exception Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 2: floating point exception Error: floating point exception Error Object: #f All steps I screened to file, which you can download - https://yadi.sk/i/_oLMVuzbsq6YX |
June 28, 2016, 02:38 |
#9 |
Dm Fo
Rep Power: 11 |
Strange error:
Warning: Invalid cp (0.000000e+00 J/kgK) for hydrogen at temperature -1.#IND00 K While initialization T=343 K, cp_H2 must be calculated. |
June 29, 2016, 01:42 |
#10 |
Dm Fo
Rep Power: 11 |
It seems I've tried all model's setting, but result is the same - error. Can someone share your own correct fluent model of pem or model from tutorial? I couldn't understand what is wrong in my model.
July 5, 2016, 01:38 |
#11 |
Dm Fo
Rep Power: 11 |
I have create new pemfc model with coarse mrsh. During calculating both I_anode and I_cathode equal to 0. Finally, calculation is collapsed. Somebony know what has happened?
January 8, 2017, 07:01 |
#12 |
A-A Azarafza
Rep Power: 14 |
The issues can arise from different sources. Mesh quality is very important, especially in through-plane direction (y direction in default). One important thing that I experience ever which makes the anodic and cathodic current density zero, is the correct modeling of the surface between the flow channels and GDL. In some cases when you do not observe the rules correctly, you might have created the mentioned surfaces as wall unintentionally. Any possible mistake in splitting the volume would result in such a flaw. Check the surfaces carefully to be ensured that the flows pass through the surfaces into the GDL layer. This was the main reason that I would receive zero current in calculations.
I hope it helps Abouzar
Regard yours |
January 8, 2017, 07:03 |
#13 | |
A-A Azarafza
Rep Power: 14 |
The issues can arise from different sources. Mesh quality is very important, especially in through-plane direction (y direction in default). One important thing that I experience ever which makes the anodic and cathodic current density zero, is the correct modeling of the surface between the flow channels and GDL. In some cases when you do not observe the rules correctly, you might have created the mentioned surfaces as wall unintentionally. Any possible mistake in splitting the volume would result in such a flaw. Check the surfaces carefully to be ensured that the flows pass through the surfaces into the GDL layer. This was the main reason that I would receive zero current in calculations. I hope it helps Abouzar
Regard yours |
April 26, 2017, 04:38 |
#14 | |
YZH
Rep Power: 9 |
July 23, 2017, 22:59 |
I managed to make it worked
#15 |
YZH
Rep Power: 9 |
August 3, 2017, 13:07 |
#16 |
Adam
Rep Power: 9 |
Can you say how did u solve it?
August 21, 2017, 05:32 |
#17 |
YZH
Rep Power: 9 |
Firstly, you should choose double precision in the Fluent Launcher.
Secondly, when you check the mesh after reading it, you will notice the WARNING in the console and do what the console told you which as the followed: "Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm." Thirdly, check the mesh again, it will okay without WARNING. |
January 4, 2018, 08:55 |
#18 |
Sakarya
Hi.
I have some problem like cp is invalid You must change discretization method as Coupled. Now The analysis is running. |
January 26, 2018, 13:32 |
need help about simulation solid oxide fuel cell
#19 |
sabrina
Rep Power: 8 |
February 2, 2018, 18:21 |
#20 |
sabrina
Rep Power: 8 |
please help me about this tutoriel i am begein work about this but i don't now how choose the boundry condition can you send it to me please urgent
Seeking Macroscopic Particle Model in Fluent | bzhang7 | FLUENT | 3 | June 25, 2022 18:54 |
How to create a 3Ds Car Model importing to FLUENT? | spysunny | Main CFD Forum | 1 | January 11, 2012 00:40 |
Why is Fluent unable to deal with my model at the micron scale? | dixylo | FLUENT | 4 | December 9, 2011 00:39 |
Fluent 12 k-w SST turbulence model | DarrenC | FLUENT | 0 | December 13, 2009 09:33 |
Covert Star-CD model to FLUENT | Lam | Siemens | 6 | June 24, 2003 21:21 |
