Save Solution Data in a Fluent Transient Simulation |
September 15, 2015, 05:52 |
anonym
I am simulating a 3D unsteady flow system in fluent. This is a periodic simulation (N periods) and would be run for N*100 timesteps. I would like to save transient data (ONLY: pressure, velocity, density, and wall shear; as I have space limit) for ONLY the last 100 time steps (i.e., from timestep (N-1)*100 to N*100). Moreover, I will pass the case onto a cluster for parallel running; so gui based commands might not be suitable in this case. Would be grateful if you please help me. Thanks a lot in advance. |
September 15, 2015, 06:13 |
Bruno Machado
Rep Power: 13 |
I think you can do it using the "Calculation Activities" in the Fluent menu. Check if the Autosave every (iteration) menu helps, otherwise you can have a look at the Execute Commands to associate it to time steps.
September 15, 2015, 06:34 |
anonym
Thanks for your advice. However, my problem is that I do not want to save at every timestep; instead, I need to save solution data only for the last 100 timesteps. Thanks. |
September 15, 2015, 22:41 |
Lucky
Rep Power: 66 |
Basically Bruno is right. Iterate the first ## time-steps without using calculation activities. Then once you hit the time-step that you want to start saving, turn on all the calculation activities. You can set up the calculation activities through GUI or TUI. If you have access to the GUI and aren't familiar with the TUI, it's probably easiest to do it with the GUI. Just bring your .cas and .dat off the cluster and open it locally when you're ready to do the swithc. Otherwise, doing it with the TUI is pretty easy to do once you learn how to enter commands through the TUI window.
However, you cannot save only the pressure, velocity, density, and wall-shear in a Fluent .dat as all the dynamical variables are always saved. You can save a limited number of variables, but it would have to be an .ascii text file or something similar and not of the Fluent .dat type, which means you wouldn't be able to load the saved files again in Fluent. |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 08:31 |
Animation of Fluent transient data | saisanthoshm88 | CFX | 22 | August 14, 2017 20:06 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 15:06 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
How to save the transient data in paraview | WaterDynamics | OpenFOAM | 0 | February 22, 2012 03:06 |
