September 12, 2015, 16:45 |
Residuals of continuity not converging2
Aja
Rep Power: 15 |
I'm simulating a turbine. The convergence of solution is monitored by checking the residuals of the numerically solved governing equations. The "viscous-spalarat-almaras" model is used, and used air with constant density. Pressure-velocity coupled scheme and pressure based solver are selected. According to the following figures, torque is increasing but the residual of continuity does not decrease and is almost constant. This turbine have a Tip-Gap(tip clearance) region. This region is small and In other words, air flow pass this region. Is there any problem? According to monitored torque, the solution is not converged. I am grateful that guide me about this case. Thanks, Best, Aja Last edited by aja1345; September 16, 2015 at 16:13. |
September 12, 2015, 19:38 |
Aja
Rep Power: 15 |
Can no-one guide?
September 13, 2015, 03:26 |
Aja
Rep Power: 15 |
Now I understand that second figure is not torque but it is total torque coefficient. How do I monitor the torque?
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
