Time saving or consuming FLUENt
Old   September 12, 2015, 02:38
Default Time saving or consuming FLUENt
sachindra
sachindra is on a distinguished road
Hi friends. I have a question. Is FLUENT time consuming or time saving software. Because when we solve a steady flow problem then it takes few minutes to converge but when we go for unsteady problem it will take more than a weak. Then What can we categorize this time factor in FLUENT. I need the the answer from any FLUENT people
sachindra is offline   Reply With Quote
Old   September 12, 2015, 04:50
AHF
AHF's Avatar
amirhossein
AHF is on a distinguished road
more than a week ?
i think it's depend on your problem and also time step setting
AHF is offline   Reply With Quote
Old   September 16, 2015, 00:20
Lucky
The time-saving vs time-consuming is more related to your modelling approach than the software.
Basically, a steady simulation is an unsteady simulation with only 1 time-step (but very large dt). It depends on whether there is any time-scale to your problem. If your problem is stationary, then the choice of dt doesn't matter explicitly and the computational cost of an unsteady versus steady simulation scales with the total number of iterations that you perform:
For unsteady: number of time steps x number of iterations per time-step
vs
For steady: number of iterations
But if your problem has transients and you are trying to arrive at a stationary point (i.e. reach steady state) then the number of time-steps needed is proportional to the time-scale of the transient process (e.g. the time-constant of the problem).
If you choose to model your problem in an expensive way, then it will become an expensive problem.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
