September 11, 2015, 09:51 |
casting solidification
giuseppe lombardo
Rep Power: 11 |
Hello everybody, I'm quite new at Ansys and I'm trying to do a 3D solidification simulation using Fluent. In particular, I'm working on an aluminum casting made from a sand casting process. I decided to use a specimen, as a representative part of my process, which has been reduced in geometry to its initial gauge length. As a result I have, as can be seen from the screenshot below, a cylindrical aluminum piece surrounded by a cast iron chill and the sand mould. What I want to figure out is how to do the simulation, starting by put the boundary conditions, passing through the mesh setting and finishing up with the computational setup.
Does any of you guys have a 'standard' procedure for this kind of work? Thanks in advance. |
Continuous casting simulation problem | luke.christ | FLUENT | 6 | November 24, 2020 08:14 |
Flow and solidification in continuous casting | lynn | Fluent Multiphase | 8 | April 2, 2019 02:24 |
Modelling Solidification in Continuous Casting | raagh77 | FLUENT | 0 | January 30, 2014 01:03 |
Casting Solidification Model | Behdad.Nayebi | FLOW-3D | 3 | January 29, 2013 09:05 |
About the solidification? | H.P.LIU | Phoenics | 1 | December 1, 2010 10:49 |
