Temp-dependent properties update
Old   September 10, 2015, 14:33
Default Temp-dependent properties update
Sepehr Mohaddes
SepeHr is on a distinguished road
I have a forced convection case with temperature-dependent fluid properties, defined as polynomials. At a certain point during the solution, I would like to "freeze" the property field (e.g. density), i.e. prevent the solver from updating the temp-dependent properties, while proceeding with iterations for the governing equations. Does anybody know if there is a way to do this in FLUENT?
SepeHr is offline   Reply With Quote
Old   September 11, 2015, 08:14
Bruno Machado
Bruno Machado is on a distinguished road
since you have a dependence on the temperature your density will be non uniform all over your domain. unless you define an average for it and change it manually from polynomial to constant, I don't think there's any other way to do it.
Bruno Machado is offline   Reply With Quote
properties evaluation, variable properties
Temperature dependent properties lcbuijs OpenFOAM Pre-Processing 4 June 26, 2015 20:28
Display temperature dependent material properties vasava OpenFOAM Post-Processing 1 November 25, 2014 06:48
Temperature dependent material properties stuart230588 CFX 1 November 21, 2013 17:36
Temperature Dependent Fluid Properties eliwide OpenFOAM Running, Solving & CFD 4 December 15, 2012 20:21
FIDAP and temp dependent mat properties PLS HELP!! SEMETAY FLUENT 1 July 14, 2006 03:04
