Too fine mesh, is that a Problem?
Old   September 7, 2015, 08:38
Default Too fine mesh, is that a Problem?
Abdalla
AS_allways is on a distinguished road
If I have a too fine mesh in my Domain for turbulent flow. Is there a physical Problem besides increasing the calculation time?
Is it possible, that the mesh, being too fine, is going to Show unphysical results?
thanks very much
AS_allways is offline   Reply With Quote
Old   September 7, 2015, 11:23
Bruno Machado
Bruno Machado is on a distinguished road
I do not think it can cause any "unphysical" problem. What can happen is if it is too fine the round-off error can be significant and cause divergence problem, but I think it is unlikely to happen.
If you think your results do not show what is expected, you might need to check your inputs.
Bruno Machado is offline   Reply With Quote
Old   September 7, 2015, 17:28
Smile
Abdalla
thanks for your answer.
for acoustic calculations I am reading the static pres over the time at one point and analyse ist afterwards with the fft tool inside FLuent.
at low velocities ~ 25m/s, a pressure inlet is not working (flow direction is reversed somehow). Is it neccessary to have high velocities for pressure inlet?
Taking air as ideal gas, fluent allways ask me to check my boundary conditions suggesting to take a pressure inlet.
Has anyone an idea how to deal with this?
Old   September 8, 2015, 07:48
Cees Haringa
CeesH is on a distinguished road
Can you elaborate in what way your mesh is 'too fine'?
CeesH is offline   Reply With Quote
fine mesh, flow, fluent, results, turbulent
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] problem in mesh output mehrzad ANSYS Meshing & Geometry 2 December 10, 2014 19:07
[ICEM] ICEM problem when doing not so fine mesh DudaAPD ANSYS Meshing & Geometry 0 April 30, 2014 17:59
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
