Use of Wall Function Heat Transfer co-efficient
Old   September 4, 2015, 05:02
Default Use of Wall Function Heat Transfer co-efficient
Mochibaru
mohibanwar is on a distinguished road
Hello Everybody,
I am currently using Enhanced Turbulence model with K-Epsilon standard wall treatment?I want to calculate the Convective heat transfer co-efficient across the wall.
I have Two queries for it:
1.Whether i should use the Wall Function Heat Transfer Coefficient or Surface Heat Transfer co-efficient?
2.As there is very fine mesh in vicinity of wall so i used Enhanced wall function.SO if it is better to use Wall Function HTC for fine mesh or not?
Your Kind suggestions will be highly appreciated.
Thanks
mohibanwar is offline   Reply With Quote
Old   September 8, 2015, 02:02
Lucky
The surface heat transfer coefficient is most likely the one you are after. The surface heat transfer coefficient is the heat flux divided by the difference between local wall temperature and the reference temperature. Don't forget to specify the reference temperature (in the reference values pane).
The wall function heat transfer coefficient is calculated in terms of the dimensionless inner variables (u*, and T*).
Radiation interface hinca CFX 15 January 26, 2014 18:11
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 22:41
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
