Modelling heat transfer in a helically coiled tube heat exchanger |
August 20, 2015, 06:28 |
Andrew Vella
Rep Power: 11 |
I am trying to model the heat transfer in a helical tube heat exchanger. I have validated a model using single-phase flow with a comparison of the simulated velocity fields and pressure drop to experimental data. However, it seems that I have a few issues with respect to the heat transfer simulation.
I have specified the inlet temperature at the velocity-inlet as well as the heat flux and heat generation rate at the wall-fluid boundary conditions. I did not change the FLUENT default temperature at the pressure outlet. Any ideas whether I am on the right track? |
August 20, 2015, 12:30 |
#2 | |
Lucky
Rep Power: 66 |
By temperature at the pressure outlet, I think you are referring to the backflow temperature specification. This temperature is only used if there is backflow. |
August 21, 2015, 08:06 |
Andrew Vella
Rep Power: 11 |
Many thanks for your reply. It seems that I may have overspecified the boundary conditions. As such I am not really interested in the wall conduction at this stage. Hence, with the return (inlet) temperature and heat flux I should be able to simulate the change in the bulk fluid temperature with flow along the heat exchanger?
September 13, 2015, 12:15 |
Anwar
Rep Power: 11 |
Could you tell me as i have a similar case ?
I tried to study axial velocity along the helical body ,, but in fluent the axial velocity does not equal that velocity. I have entered the inlet velocity b.c as absolute velocity,,the problem does not persist. Also,Is there availability to get the axial velocity at any cross section/plane using the angle through the planer ? |
fluent 14 to fluent 15., heat transfer boundary |
Turbulent heat transfer in a plate heat exchanger | P_P | Main CFD Forum | 0 | July 16, 2015 09:46 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
concentric tube heat exchanger | satya | CFX | 4 | January 16, 2002 09:06 |
