Bad cd at high angles of attack | 2d airfoil
Old   August 18, 2015, 08:44
Default Bad cd at high angles of attack | 2d airfoil
koalabryant is on a distinguished road
Hi¡¡
I am simulating a 2d airfoil (Naca 64A010) and I got very good results with SST transitional mode, but as of 8º I got a bad cd compare to experimental results, as you can see in the picture I've uploaded.
I have tried almost everything but I can't get good results at high AoA.
Now I was wondering if it because in the experimental results they have an open trailing edge, and my simulation is with a closed trailing edge.
My parameters are
Re6e6
Transient, Step size: 0.001 Max iterations: 10
y+<1
C-Mesh 150000 cells (15c front x 20c back) orientating the back part of the mesh ~ half AoA
Thank you¡¡
koalabryant is offline   Reply With Quote
[snappyHexMesh] bad snap phase with high cell count Tensian OpenFOAM Meshing & Mesh Conversion 10 May 13, 2014 11:37
NACA 0012 Different Angles of Attack Arvind CFX 10 March 18, 2014 17:43
High Angle of Attack w0er Main CFD Forum 3 March 8, 2005 12:05
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
