Creating a fluid flow through cavity
Old   August 17, 2015, 13:12
Default Creating a fluid flow through cavity
Jayant
Jayant is on a distinguished road
I want to simulate the flow of a fluid around a complicated geometry. In this case a knee joint which is inside a fixture of similar shape just a little bigger to provide channel for flow all around the joint.
I am facing trouble using the fill option to generate fluid channel. Any suggestions?
Jayant is offline   Reply With Quote
abrasive flow machining, fill cavity
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Robust Algorithms for Fluid Flow aryan Main CFD Forum 2 February 6, 2013 09:46
Constant flow rate through a small area inside the fluid domain. robingilbert OpenFOAM 7 October 4, 2010 17:19
