August 16, 2015, 07:53 |
Shell conduction on pipe wall
Tal Eluk
Rep Power: 11 |
Hi all
I'm using "Shell conduction" with a non zero "wall thickness" in a pipe wall in order to simulate an isolating layer around the pipe. (fluent 14.5 -3D). the general question is: is fluent building the shell cylindricaly around the pipe (as i hope it dose) or is this option works only for Cartesian geometries? more specifically: if I have a 0.1 [m] radius pipe, and i'm specifying a 0.1[m] wall thickness to the "shell conduction", will it build a cylindrical shell from r=0.1 to r=0.2 around the pipe? Thanks, Tal. |
August 18, 2015, 10:16 |
Lucky
Rep Power: 66 |
Good question. A virtual mesh is generated when you use the shell conduction feature. But, that mesh does not have the usual mesh properties (x,y,z coordinates, etc). It is also displayed at the same location at the original wall. This leads me to think that the shell conduction model is still a thin-wall model (using 1d calculations), which seems to make sense otherwise you should just grid the region explicitly. Just my guess, since without having the mesh coordinates and cell properties it would be hard to debug and figure out exactly.
August 18, 2015, 10:30 |
Tal Eluk
Rep Power: 11 |
thanks for your reply LuckyTran.
creating the wall myself, and meshing it myself will solve the problem. but... - I want to avoid recreating the geometry. - i want to know if i can count on fluent to do it for me |
May 31, 2018, 07:19 |
#4 | |
Oliinyk Vladyslav
I've tested this creating many layers and watching the temperature distribution along the height of the virtual solid, and conclusion is yes, shells are built cylindrically on a pipe. |
Fixed Wall Temperature Pipe With Odd Results | khoopes | CFX | 5 | June 15, 2015 08:58 |
transient conduction in a wall | chabib | FLUENT | 5 | September 5, 2013 06:55 |
shell conduction setup | chinna | FLUENT | 15 | May 5, 2013 10:26 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
cellSet - Divide Patch Wall in Pipe for implementation different BCs | franzi_ | OpenFOAM | 3 | May 13, 2012 11:04 |
