Sanjiv Paudel
Rep Power: 10 ![]() |
Hello all,
I am quite stuck in the adjoint solver. Is it possible to optimize the twist of a wing without changing the camber and chord for the airfoil while doing 3d wing optimization in adjoint solver? Any ideas would be appreciable!! Thanks, |
Claus Abt
Rep Power: 15 ![]() |
You can define the wing model without changing camber or chord and apply a twist to the profile. You can even map the adjoint solution to the parametric model (the latter is only available in the commercial version). If you are a student you can get a full license that allows that, too.
Sanjiv Paudel
Thanks..
Rep Power: 3 ![]() |
Hi dear friend,
I have the same problem. Did you manage to keep the airfoil chord and camber fixed and unchanged while optimizing ? |
#5 | |
#6 | |
I have the same problem. Can you help me how to keep the chord of a 3D wing fixed and unchanged while doing optimization with Fluent's adjoint solver ? Thanks in advance. Regards. |
Claus Abt
HI there,
Here is an example of a parametric wing in CAESES that allows to change the angle of the wing along the span and keeps the same chord and camber. Cheers Claus PS: if you want to have the project file for CAESES, get in touch with me via contact form on our website, please. |
#8 | |
I don't have your website address, how and where can I send you a message ? |
#9 |
Claus Abt
#10 |
#11 |
Claus Abt
Yes, please. Refer to our discussion on CFD online, please.
#adjointsolver |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Fluent Adjoint Solver for compressible flow | b.shuvayan | FLUENT | 2 | January 30, 2015 07:27 |
RANS optimization of Onera M6 wing | diwakaranant | SU2 Shape Design | 8 | October 21, 2013 14:57 |
Adjoint Solver & Mesh Motion | dancfd | OpenFOAM Running, Solving & CFD | 1 | November 9, 2011 08:26 |
Viscous adjoint solver | Steve | Main CFD Forum | 1 | March 7, 2002 05:05 |
