Valve Design Flow Forces, Report moment
Old   August 10, 2015, 09:15
Lightbulb Valve Design Flow Forces, Report moment
Mans Man
Mans1234 is on a distinguished road
Hello ..
I am designing a rotary plate valve where orifice is created by the rotary motion of a rotor plate between two stator plates.
At rotor rotation of 1.25 deg supply pressure if connected to the port A. I am using inlet pressure of 10 bar and outlet pressure = 0. k-e realizable turbulence model.
I need to calculate flow torque. where the center of rotation for the rotor is the origin and it rotates about Y-axis.
I tried: Reports > Forces > Moments > moment center (0, 0, 0), Moment Direction (0, 1, 0)
Remark: I got low values if moment direction is (0,1,0) or (1,0,0) ~ 0.05 Nm
While it is 0.4 Nm at moment direction (0,0,1)
Thanks in advance ..
Mans1234 is offline   Reply With Quote
Old   August 10, 2015, 18:28
fresty is on a distinguished road
I guess you would probably need to share a couple of images/ sketch to support explanation of your system esp. the coordinate frames...
Just a few thoughts... If the rotating disc axis is parallel/ coaxial to the flow direction then I am not sure why do you expect high torque in the same axis.. per my understanding (assuming I did get the hang of your model) the maximum torque should be in the direction of pushing force on the disc i.e. surface plane of rotating plate perpendicular to flow direction..
fresty is offline   Reply With Quote
ansys, cfd, fluent, hydraulic valve, simulation
LES of channel flow: data, case files, technical report. tiam OpenFOAM Running, Solving & CFD 34 June 12, 2023 09:11
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Internal Flow - Physical Design Blooper SU2 2 August 12, 2014 19:38
Ball valve flow in solidworks nikesh FloEFD, FloWorks & FloTHERM 10 December 10, 2013 09:40
CFD Application in hydraulics valve flow Roger Yang Main CFD Forum 11 February 11, 1999 17:53
